A seamless integrated platform experience
The TrendMiner analytics platform consists of 3 Hubs each with their own strengths (TrendHub for sensor timeseries visualization & analysis; ContextHub for knowledge sharing, process event visualization & analysis; DashHub for bringing your views and analysis results together for personal follow-up or sharing with your co-workers), and with this release we are further improving the integration to foster an even stronger analytics experience from spotting sub-optimal operations / energy-usage / … in DashHub, to visualizing related anomalies / defects / … in ContextHub, to deep-diving into the related sensor data for root-cause analysis in TrendHub.
What does this mean for our users?
A Unified Monitoring Center, which brings together the monitor configuration and inbox and provides easier access to historical results and related searches, accessible from all Hubs.
All TrendHub visualizations are now available DashHub, including stacked trends, histograms and scatterplots as well as improved (regular) trend visualization.
All ContextHub visualizations are now available DashHub, including table & Gantt displays, so that you can build even better, more extensive and more complete dashboards.
Easily compare the process events from ContextHub based on sensor timeseries data by visualizing multiple context items at once in TrendHub, eg. to easily compare batch run data.
Get suggestions for which component to use when creating a context item, depending on the view you have open or which tags, attributes or assets you recently used.
