TrendMiner connectivity
TrendMiner supports 3 types of data:
time series data
context data
asset data
For each of these data types TrendMiner supports out-of-the-box connectivity options. Next to the connectivity options which are shipped by default there are also some custom connectivity options and there is the TrendMiner connector API which allows you to write your own connector.
Time series connectivity
CSV import: more information can be found in the user documentation
Historian connectivity:
PI OLEDB 2010, 2016+, 2017 R2, 2017 Enterprise
PI AF SDK 2010 R3+, 2017 R2 SP1, 2018
AspenTech IP21 v7, v8, v10, v11
GE Proficy 4.5, 5.5, 7.0 SP4, 8.1
Yokogawa Exaquantum 2.85, 3.02, 3.10, 3.15
Honeywell PHD R3.30, R4.00
Aveva Wonderware 2014 R2 SP1 P02, 2017
Cumulocity
Write your own connector using the TrendMiner connector API
Context connectivity
Aveva PI: PI AF SDK 2017 R2 SP1 or higher
Asset connectivity
TrendMiner supports the following options to get your asset data available in TrendMiner:
