Linux Deployment
Linux Deployment
TrendMiner can be installed on CentOS 7 and Red Hat Enterprise Linux 7. Other distributions based on Red Hat Enterprise Linux 7 might work but are not officially supported. During the installation and any future updates, access to the official repositories or a mirror of them is required.
Prepare the Installation
Allocate Storage TrendMiner stores application data and logs in /mnt/data. Ensure that this directory has sufficient free disk space.
Firewall
TrendMiner controls the firewall of the system. Additional ports that need to be open for monitoring or other agents need to be configured as documented in Opening Additional Firewall Ports.
Install TrendMiner
Copy the installation archive to the destination server:
$ scp <installation file> <user>@<server>:<path>
Extract the installation archive:
# tar -xf <installation file>
Run the installation script and send the output to a log file. Choose any location to save this log file:
# ./install-trendminer.sh -s server_name | tee trendminer-installation.log
The ‘server_name’ has to be the FQDN excluding the protocol of the server. An example: ./install-trendminer.sh -s my_tm_url.com
Choose the correct installation method.
What do you want to do:
[1]Install Single node [2]Install Cluster [3]Deploy application ->
Type 1 to start the single node installation. Wait for the installation to finish. Continue by configuring TrendMiner in ConfigHub.
Opening Additional Firewall Ports TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22) and http(s) (tcp/80, tcp/443) are allowed.
"allow_icmp": true,
"open_tcp": [
5666,
10050
}In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
# python -m json.tool < /etc/ansible/facts.d/iptables.fact
# cd /mnt/data/ansible-playbooks # ansible-playbook agent/configure-tm-agent.yml \ -i /var/www/dsquare-appliance/hosts
The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
By default the metrics are not exposed. To access them, first allow port 9100 as described in the Opening Additional Firewall Ports section. Then scrape the /federate endpoint of the Prometheus instance.
scrape_configs:
- job_name: federated-trendminer
honor_labels: true
honor_timestamps: true
scrape_interval: 15s
scrape_timeout: 10s
metrics_path: /federate
static_configs:
- targets:
- <my-trendminer>:9100AlertManager can then handle alerts:
groups:
- name: TrendMiner rules
rules:
- alert: instance_down_2m
for: 2m
labels:
severity: Critical
annotations:
description: TrendMiner DOWN for 2 minutes
summary: TrendMiner DOWN
