Application Enhancements overview
Improved tag-search performance
Our tag-search procedures have been changed in order to improve the performance when a high number of tags are being used. When searching for a tag via the new procedures:
  • the query requires a minimum length of 3 characters;
  • the first 200 results are returned;
  • results are sorted on name (ascending).
Suggestions for tags/views when visualizing context items
In TrendHub Next Generation (currently in beta), we’ve made improvements to the “visualize” option for context items. By adding a list of suggested tags and views to the visualize panel, based on the user’s most recent activity (up to 10 each), it is now much easier for users to find back relevant tags to include in the visualization. Selecting a recently used tag/attribute will add that tag to the list of selected tags to visualize. Selecting a recently used view will select all tags from that view.
TrendMiner version in user drop-down
In TrendHub Next Generation, ContextHub and DashHub, you can now, as a user, consult the version of TrendMiner which is installed.
This can simply be done by clicking on your user name which is located in the top right corner, in any of these hubs.
Admin: Improved insights in the integration-status of OSIsoft PI AF data sources
In order to increase the agency of TrendMiner administrators, specifically in case of integration issues with ContextHub data sources (Asset Frameworks & Event Frames), we have added a dedicated “Diagnostics” page in the “Data” section of ConfigHub.
The “Diagnostics” page is accessible through the “Data” section in ConfigHub, and breaks down synchronization diagnostics into the following sections & sub-sections:
  • Event Frame Sync
    • Live Sync
    • Excessive Interval Sync
    • Historical Sync
    • Failed Context Items
  • Asset Framework Sync
    • History
