TrendMiner connectivity
TrendMiner supports 3 types of data:
  • time series data
  • context data
  • asset data
For each of these data types TrendMiner supports out-of-the-box connectivity options. Next to the connectivity options which are shipped by default there are also some custom connectivity options and there is the TrendMiner connector API which allows you to write your own connector.
Time series connectivity
Context connectivity
  • CSV import: more information can be found in the user documentation
  • Historian connectivity:
    • Aveva PI: PI AF SDK 2017 R2 SP1 or higher
  • ODBC (Context SQL Sync)
Asset connectivity
TrendMiner supports the following options to get your asset data available in TrendMiner:
