Opening Additional Firewall Ports
TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22) and http(s) (tcp/80, tcp/443) are allowed.
Additional ports can be opened by creating a configuration file, owned by root: /etc/ansible/facts.d/iptables.fact
"allow_icmp": true,
"open_tcp": [
5666,
10050
} In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
# python -m json.tool < /etc/ansible/facts.d/iptables.fact
# cd /mnt/data/ansible-playbooks
# ansible-playbook agent/configure-tm-agent.yml \
-i /var/www/dsquare-appliance/hosts The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
scrape_configs:
- job_name: federated-trendminer
honor_labels: true
honor_timestamps: true
scrape_interval: 15s
scrape_timeout: 10s
metrics_path: /federate
static_configs:
- targets:
- <my-trendminer>:9100 AlertManager can then handle alerts:
groups:
- name: TrendMiner rules
rules:
- alert: instance_down_2m
for: 2m
labels:
severity: Critical
annotations:
description: TrendMiner DOWN for 2 minutes
summary: TrendMiner DOWN
