Time series connectivity
TrendMiner supports the following time series connectivity options, divided into 'plug & play' connectivity providers and providers which require query definition.
Table 4. Supported 'plug & play' time series connectivity
Type / Vendor / Historian / IoT platform
Supported versions
Deprecated versions
Notes
TrendMiner connector required
Aveva PI
PI OLEDB 2010, 2016+, 2017 R2, 2017 Enterprise
Yes
PI AF SDK 2018, 2024
2010 R3+, 2017 R2 SP1
Yes
AspenTech IP21
v7, v8, v10, v11
Yes
GE Proficy How to connect to GE Proficy?
9.1, 2022 (v10), 2023 (v11), 2024 SIM1 or higher, 2025
4.5, 5.5, 7.0 SP4, 8.1
Yes
Proficy Cloud
On demand: contact your CSM
Yes
Yokogawa Exaquantum
3.10, 3.15, 3.20, 3.30, 3.40, 3.50, 3.60
2.85, 3.02
Yes
Honeywell PHD
R4.30
R3.30, R4.00, R4.10
Yes
Aveva Wonderware
2014 R2 SP1 P02, 2017, 2020, 2023
Yes
AWS IoT SiteWise
No
Canary
2024, 2025
2023
No
CSV import
No
Table 5. Supported time series connectivity which requires query definition
Supported versions
Notes
Generic ODBC[a]
Yes
WebHost / AppHost
ODBC provider (deprecated)
Replaced with Generic ODBC
Yes
WebHost only
OleDB provider (deprecated)
Yes
WebHost only
SQLite provider (deprecated)
Replaced with SQLite using Generic ODBC
Yes
WebHost only
Cumulocity [a]
Using Generic ODBC connection to DataHub
Yes
Microsoft Azure Data Explorer (Kusto ADX)
No
Amazon Timestream
No
Generic JDBC [a]
Additional JDBC drivers must be installed.
No
PostgreSQL [a]
42.7.13
Using Generic ODBC / Generic JDBC
Yes (ODBC) / No (JDBC)
Microsoft SQL Server (MSSQL) [a]
13.4.0.jre11
MariaDB [a]
3.5.10
SQLite [a]
Using Generic ODBC
Yes
Databricks [a]
3.4.2
Using Generic JDBC
No
Snowflake [a]
4.3.3
Using Generic JDBC
No
Write your own connector using the TrendMiner connector API
No
[a] Contact TrendMiner support to set up this connection.
