Prepare the Installation
Allocate storage
TrendMiner stores application data and logs in /mnt/data. Ensure that this directory has sufficient free disk space.
Install prerequisites for Ansible
The following actions are needed to install Ansible and be able to run the full installation procedure.
yum install centos-release-ansible-29
Check IP address usage
