Linux Deployment
TrendMiner can be installed on CentOS 7 and Red Hat Enterprise Linux 7. Other distributions based on Red Hat Enterprise Linux 7 might work but are not officially supported. During the installation and any future updates, access to the official repositories or a mirror of them is required.
TrendMiner has no extra requirements when installing on a customer-provided CentOS 7 or Red Hat Enterprise Linux 7 system outside of the software that is available in the official operating system repositories.
TrendMiner currently does not support deploying a virtual disk (.ova or .vhd) in a private cloud.
Prepare the Installation
Allocate storage
TrendMiner stores application data and logs in /mnt/data. Ensure that this directory has sufficient free disk space.
Install prerequisites for Ansible
The following actions are needed to install Ansible and be able to run the full installation procedure.
yum install centos-release-ansible-29
Check IP address usage
Install TrendMiner
Download the TrendMiner installation file from the TrendMiner download site. The installation file is the
trendminer-<version>.tar.gzfile.Copy the installation archive to the destination server.
scp <installation file> <user>@<server>:<path>
Extract the installation archive.
tar -xf <installation file>
Run the installation script (first it will validate if Ansible is installed) and send the output to a logfile. Choose any location to save this log file.
./install-trendminer.sh -s server_name | tee trendminer-installation.log
Important note: The ‘server_name’ has to be the FQDN excluding the protocol of the server. An example: ./install-trendminer.sh -s my_tm_url.com
When ansible is not installed, choose yes to install Ansible from the official Ansible CentOS repositories. If you choose no, please be sure that it’s possible to install Ansible.
Do you want to configure the Ansible repository for CentOS (y/n)
Opening additional firewall ports
TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22) and http(s) (tcp/80, tcp/443) are allowed.
"allow_icmp": true,
"open_tcp": [
5666,
10050
} In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
python -m json.tool < /etc/ansible/facts.d/iptables.fact
cd /mnt/data/ansible-playbooks ansible-playbook agent/configure-tm-agent.yml -i /var/www/dsquare-appliance/hosts
The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
scrape_configs:
- job_name: federated-trendminer
honor_labels: true
honor_timestamps: true
scrape_interval: 15s
scrape_timeout: 10s
metrics_path: /federate
static_configs:
- targets:
- <my-trendminer>:9100 AlertManager can then handle alerts:
groups:
- name: TrendMiner rules
rules:
- alert: instance_down_2m
for: 2m
labels:
severity: Critical
annotations:
description: TrendMiner DOWN for 2 minutes
summary: TrendMiner DOWN
