Why am I being logged out?
Introduction
In certain cases, this stricter security framework can lead to intermittent log-outs happening for end users. Regardless of your setup, a user will never be logged out under 30 minutes. If users happen to get logged out after periods of activity/inactivity less than 30 minutes, this indicates there is a configuration issue that needs to be addressed.
In 95% of observed cases, this phenomenon is caused by a time mismatch between the client (i.e. the user’s computer) and the TrendMiner server time. Computer time is an important element in security, used from SSL certificate expiration dates to the lifecycle management of an access token, identifying the validity of your current session.
Step 1 – Ensure TrendMiner has an NTP server configured
The TrendMiner server time is managed through configuration of an NTP server to synchronize the clock with. The NTP configuration is done in ConfigHub. See more information here.
If there is no NTP server configured, this should be the first thing to do. Without configuration of an NTP server, it is possible the TrendMiner server time deviates from the user’s local machine, potentially causing the logout issues.
Step 2 – Get the local machine time
If logout issues still occur, the next step includes taking a closer at the time on the affected user’s local machine. You can do a simple check looking at the clock on a Windows machine – click on the time in your taskbar to open more details.
Double-check that the time on the local machine is in line with the NTP server it is configured to mirror. This could be a global NTP server (e.g. Microsoft, Google offer public NTP servers) or a Domain Controller.
In some cases, firewall issues or other synch problems, could cause the local machine to go out of synch with the company’s configured NTP. If this is the case, resolve this problem before continuing to troubleshoot.
Step 3 – Get the TrendMiner server time
  • TrendMiner cannot reach the configured NTP server (e.g. firewall issue if you’re pointing to a public NTP)
  • TrendMiner is configured to use a different NTP than the user’s local machine, causing a mismatch between the two
timedatectl status
