Step 4: Connect
TrendMiner supports 3 types of data:
For each of these data types TrendMiner supports out-of-the-box connectivity options. Next to the connectivity options which are shipped by default there are also some custom connectivity options and there is the TrendMiner connector API which allows you to write your own connector.
Some connections are set up directly from the TrendMiner appliance server to the data source and some need an intermediate component like the TrendMiner connector, also known as 'Plant Integrations'. For data sources which are connected via the TrendMiner connector a separate installation of this connector is required before a connection to that data source can be set up.
Access Management
Only access for time series data sources and expert functionality (notebooks and custom calculations) is managed in ConfigHub.
Permissions on assets and context data is managed in ContextHub. Consult the user documentation for more information on context and asset permissions.
  • Domain:
    • "DATASOURCE": for time series data source access permissions
    • "TIMESERIES_BUILDER": for notebooks and custom calculations access permissions
  • Entity:
    • Using the DATASOURCE domain: Enter the name of the data source, as configured in ConfigHub -> Data sources or use "ALL" to indicate the collection of all data sources.
      Notice
      Only alphanumerical characters and '-' or '_' are allowed in data source access permissions. In case you have a data source name using special characters, please rename the data source before assigning an access permission to it.
    • Using TIMESERIES_BUILDER domain, add one or more of the following "Entity" values:
      • NOTEBOOK: access to MLHub
      • CUSTOM_CALCULATIONS: access to the custom calculations in the TrendHub tag builder.
      Notice
      In the TIMESERIES_BUILDER domain, entity "ALL" is not supported. Each entity must be added individually.
  • Members: Users, groups or clients you want to grant access permission for the domain
access_management_add-2023.R3.0
No subgroup inheritance
The system only checks if a user is directly in the user group assigned the permission. It does not consider membership in subgroups of that user group (subgroups do not inherit permissions from the parent group).
