TrendMiner installation
These guidelines provide a full overview of the requirements and steps for a successful self-service installation and configuration of TrendMiner. All installation files can be downloaded from the TrendMiner download portal. To access this portal you need a login which you can get via your TrendMiner contact.
TrendMiner can be deployed in 2 ways:
As a SaaS instance: In this scenario, TrendMiner will run, maintain and update the platform. This is the preferred, future-proof deployment model. In the SaaS scenario, our teams will take care of the installation and reach out to discuss configuration and connectivity.
As a self-hosted option: in this scenario TrendMiner can be deployed as a single node instance on any server running AlmaLinux 9 or Red Hat Enterprise Linux 9:
Virtualized environments (VMs), e.g. VMware, Hyper-V, ...
Private cloud infrastructure, e.g. Amazon AWS, Microsoft Azure, ...
Caution
This documentation walks you through the steps required to set up a fully functioning TrendMiner environment. For self-hosted options, more initial configuration is needed and more maintenance will be required, such as certificate management, etc. Additional input may be required from your organisation's IT department, so it is advised to plan ahead accordingly.
TrendMiner will support when running into issues, but will always point back to this documentation if steps were skipped or requirements are not met. If so desired, TrendMiner can also help with more hands-on support. Reach out to your contact to discuss pricing.
