Step 1: Prepare
Good preparation makes half the work. This section provides an overview of the high-level TrendMiner architecture, server requirements, who to involve in the installation process and a preparation checklist to ensure a smooth installation journey.
Who to involve?
Depending on your organisations size and structure, multiple people from your IT and OT organizations might need to be involved to get TrendMiner up and running, configured and connected to your data sources. We recommend reaching out to everyone involved and discussing the installation process early to avoid any delays later on.
The following roles are typically involved:
Server provisioning and maintenance
To provide the necessary (virtualized) servers according to the requirements, create and maintain snapshots of the Virtual Machine and provide console access for troubleshooting when needed.
Networking specialists
To make the necessary network port and firewall configurations to allow traffic between the TrendMiner server, Plant Integrations and your data sources, and to allow end users to access TrendMiner through their web browser. They will also be able to help out on DNS, NTP and mail relay configuration or connect you to the people who can.
System security
To generate (and update) the necessary SSL certificates for secure access to TrendMiner.
Data source admins
To provide access to the data and deliver data queries if you use a generic connector.
SAML/LDAP admin
While we recommend managing TrendMiner users locally within TrendMiner for initial Explore programs, it is possible to connect TrendMiner to your SAML or LDAP user management system. Involve your SAML/LDAP admin to set up the configuration.
Make sure to discuss responsibilities during the initial installation process as well as for future upgrades and support needs.
Preparation checklist (single node)
Validate the TrendMiner architecture within your organization. Discuss any open questions with TrendMiner Support.
Provision the necessary servers, according to the requirements discussed earlier.
Involve all IT and OT stakeholders early. Read through the installation documentation and discuss roles and responsibilities. Discuss any open questions with TrendMiner Support.
Gather the required input for the server config: IP address and netmask, network gateway, DNS servers, NTP servers, mail relay.
Prepare SSL certificates for secure TrendMiner access (more information Configure SSL/HTTPS)
Prepare input for data source connection(s) (more information Step 4: Connect)
[Optional] Prepare input for SAML or LDAP user management integration (more information Identity Providers)
Server requirements (single node)
Resource | Minimum | Minimum with MLHub[a] | Recommended | ||||||||||||||||||||||||||||||||||||||||||||||
vCPU | 16 | + 1 core per 4 active kernels (per user) + 1 core per 8 notebook tiles (per user per dashboard) | 16 | ||||||||||||||||||||||||||||||||||||||||||||||
RAM | 64GB | + 1GB per active kernel (per user) + 256MB per notebook tile (per user per dashboard) | 96GB | ||||||||||||||||||||||||||||||||||||||||||||||
Disk | SSD, 200GB + 300GB, 250MB/s | SSD, 200GB + 300GB, 250MB/s | SSD, 200GB + 300GB, 250MB/s | ||||||||||||||||||||||||||||||||||||||||||||||
[a] Contact your Customer Success Manager for more information on MLHub Notebook and Machine Learning Model capabilities |
Execute the lscpu
command and verify that the "CPU(s)" listed is in line with the minimal system requirements.
Execute the free -m
command and verify that the "Total - Mem" listed is in line with the minimal system requirements.
Disk type: To verify your disk is not rotational (like a HDD) execute the
lsblk
command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.Disk space: The required disk space highly depends on the usage of the system: number of users and the amount of items they save on the system + the number of tags which are added and indexed. If usage increases further disk space increases might be required.
Disk speed: TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed:
The root volume contains system logs and services and should have at least 10GB of disk space.
The /mnt/data volume stores all TrendMiner application data and logs. Important notes about the /mnt/data mount point:
xfs_info /mnt/data/
. In the resulting output you should seeftype=1
. If ftype=0 the volume should be reformatted to support d_type.
The available volumes and disk spaces can be verified with the df -h
command.
TrendMiner uses the root user to run commands (e.g. during installation and upgrades). The root user needs sudo permissions. To verify this is the case execute the sudo id
command. The result should be uid=0(root) gid=0(root) groups=0(root)
For AlmaLinux 9:
AlmaLinux 9 - BaseOS
AlmaLinux 9 - Extras
AlmaLinux 9 - AppStream
For RHEL 9:
rhel-9-for-x86_64-appstream-rpms
rhel-9-for-x86_64-baseos-rpms
To list all available repos on the system use dnf repolist
. TrendMiner will add another repo called tm-appliance
during installation.
To check which repos are configured, use the dnf repolist -v enabled
command and check the Repo-baseurl
Make sure a DNS server is correctly configured. Verify the configured DNS server by executing cat /etc/resolv.conf
. If a NetworkManager is managing your network settings, make sure the DNS config is not lost after a reboot by verifying the resolv.conf file still contains the DNS server after a reboot.
Before starting the installation make sure the DNS server is not running. To check if a DNS server is running and to stop and disable the DNS server use the following commands:
lsof -i :53 systemctl stop systemd-resolved systemctl disable systemd-resolved
TrendMiner installation requires ansible to be installed on the server.
It's required to use the EPEL repository for installing ansible https://docs.fedoraproject.org/en-US/epel/ (the ansible-core package is missing some plugins which TrendMiner requires and can therefore not be used!)
On RHEL9:
subscription-manager repos --enable codeready-builder-for-rhel-9-$(arch)-rpms dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
On AlmaLinux9:
dnf config-manager --set-enabled crb dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
In case it is not possible to enable the codeready-builder-for-rhel-9 repo on your server (e.g. you do not have a subscription and you get a message 'Repositories disabled by configuration
') please make sure to host the repo on a satellite or as a workaround you can skip the repo enablement and manually install the epel and ansible packages.
TrendMiner requires the iptables and iptables-nft packages which can be installed using the following command:
dnf install -y iptables iptables-nft
The TrendMiner appliance uses Kubernetes (K3S) as its infrastructure layer, which needs a range of IP addresses for internal communication between different pods and services. These IP addresses should not be used by other applications/servers/clients which need to connect to TrendMiner or to which TrendMiner needs to connect, e.g. IPs assigned to clients connecting to TrendMiner, an AD server configured in TrendMiner, a connector to which TrendMiner needs to connect, ...
If your company is already using one or more of these IP addresses it is possible to change the IP ranges for TrendMiner. In this case please contact TrendMiner support before starting the installation.
More info about the appliance IP requirements can be found here: Appliance IP requirements FAQs
sudo ps -ef | grep mdatp
)Trend Micro AV (
sudo ps -ef | grep ds_agent
)Crowdstrike (
sudo ps -ef | grep falcon-sensor
It is also known that if third party software writes data to /etc/init.d it can cause a failure of the TrendMiner installation script: e.g. error: unpacking of archive failed on file /etc/init.d
. Please make sure to not install third party software. If this is required by company policy please align first with TrendMiner support for a suitable solution.
option 1 (preferred):
to: license.trendminer.cloud (DNS based IP whitelisting)
port: TCP 443
option 2:
to: 13.248.161.236 and 3.33.158.180
port: TCP 443
