Server requirements (single node)
Table 1. TrendMiner Server - Hardware requirements
Resource
Minimum
Minimum with MLHub[a]
Recommended
vCPU
16
+ 1 core per 4 active kernels (per user) + 1 core per 8 notebook tiles (per user per dashboard)
16
RAM
64GB
+ 1GB per active kernel (per user) + 256MB per notebook tile (per user per dashboard)
96GB
Disk
SSD, 200GB + 300GB, 250MB/s
[a] Contact your Customer Success Manager for more information on MLHub Notebook and Machine Learning Model capabilities
Additional CPU and Memory requirements
Additional disk requirements
  • Disk type: To verify your disk is not rotational (like a HDD) execute the lsblk command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.
  • Disk space: The required disk space highly depends on the usage of the system: number of users and the amount of items they save on the system + the number of tags which are added and indexed. If usage increases further disk space increases might be required.
  • Disk speed: TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
    The following commands can be used to measure the disk speed:
    #create a test file in /run which we will write to /mnt/data
    dd if=/dev/urandom of=/run/test.bin bs=1M count=1024 status=none
    #write the test file to /mnt/data and measure the disk write performance of /mnt/data. This is the result to take into account.
    dd if=/run/test.bin of=/mnt/data/test1.bin bs=1M conv=fsync
    #remove the test files again
    rm /run/test.bin /mnt/data/test1.bin
Prep the mount points
The root volume contains system logs and services and should have at least 10GB of disk space.
The /mnt/data volume stores all TrendMiner application data and logs. Important notes about the /mnt/data mount point:
  • Ensure that this directory has sufficient free disk space. If TrendMiner runs out of available disk space services will start failing leading to downtime for the users. Ensure that at least the minimal required disk space is available and keep in mind that as usage of the system grows, the available disk space might need to be extended.
  • Make sure /mnt/data is mounted to a non-volatile/permanent disk to avoid a broken TrendMiner installation after a server reboot. To make sure this is the case, create a dummy file in /mnt/data, perform a reboot and verify your dummy file is still available.
  • TrendMiner requires d_type support for the /mnt/data volume. To check this run command xfs_info /mnt/data/. In the resulting output you should see ftype=1. If ftype=0 the volume should be reformatted to support d_type.
Root permissions
Repository access
For AlmaLinux 9:
  • AlmaLinux 9 - BaseOS
  • AlmaLinux 9 - Extras
  • AlmaLinux 9 - AppStream
For RHEL 9:
  • rhel-9-for-x86_64-appstream-rpms
  • rhel-9-for-x86_64-baseos-rpms
DNS server
Before starting the installation make sure the DNS server is not running. To check if a DNS server is running and to stop and disable the DNS server use the following commands:
lsof -i :53
systemctl stop systemd-resolved
systemctl disable systemd-resolved
When a DNS config is changed after initial installation a reboot of the server is required to ensure the new DNS config is used by TrendMiner.
Ansible installation
TrendMiner installation requires ansible to be installed on the server.
It's required to use the EPEL repository for installing ansible  https://docs.fedoraproject.org/en-US/epel/ (the ansible-core package is missing some plugins which TrendMiner requires and can therefore not be used!)
On RHEL9:
subscription-manager repos --enable codeready-builder-for-rhel-9-$(arch)-rpms
dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm
dnf install ansible
On AlmaLinux9:
dnf config-manager --set-enabled crb
dnf install ansible
iptables installation
sudo dnf remove iptables iptables-libs iptables-services
sudo dnf config-manager --set-disabled epel
sudo dnf install iptables iptables-services iptables-nft --disablerepo=epel
Network requirements
  • Gigabit Ethernet or better is required for TrendMiner to work.
  • The TrendMiner appliance uses Kubernetes (K3S) as its infrastructure layer, which needs a range of IP addresses for internal communication between different pods and services. These IP addresses should not be used by other applications/servers/clients which need to connect to TrendMiner or to which TrendMiner needs to connect, e.g. IPs assigned to clients connecting to TrendMiner, an AD server configured in TrendMiner, a connector to which TrendMiner needs to connect, ...
    If your company is already using one or more of these IP addresses it is possible to change the IP ranges for TrendMiner. In this case please contact TrendMiner support before starting the installation.
    More info about the appliance IP requirements can be found here: Appliance IP requirements FAQs
Other software
  • Microsoft Defender Advanced Threat Protection (sudo ps -ef | grep mdatp)
  • Trend Micro AV (sudo ps -ef | grep ds_agent)
  • Crowdstrike (sudo ps -ef | grep falcon-sensor)
Proxies
If you have a proxy configured TrendMiner installation might fail. Please make sure no proxy is configured until after the installation of TrendMiner.
After the installation, please make sure the following domains and IPs are excluded from using the proxy: localhost, 127.0.0.1, .cluster.local, service.consuland all the IP ranges used by K3S as documented here: Appliance IP requirements FAQs.
option 1 (preferred):
  • to: license.trendminer.cloud (DNS based IP whitelisting)
  • port: TCP 443
option 2:
  • to: 13.248.161.236 and 3.33.158.180
  • port: TCP 443
Additional firewall rules
In case you are running a deployment on singlenode you have the ability to install additional firewall rules, for agents allowing to monitor the Server or a inventory for instance
To provide flexibility in managing firewall rules, TrendMiner created a default file located at /etc/nftables/custom.nft.
This will allow you to add your own custom firewall rules without modifying the core configuration files.
All ports not known to TrendMiner are blocked by default no incoming traffic is allowed unless explicitly permitted by a rule.
To install the a new rule, follow this procedure below:
  1. Open the custom rules file: To add a rule, first open the /etc/nftables/custom.nft file in your preferred text editor. You may need root privileges to edit this file:
# vi /etc/nftables/custom.nft
2. Add your custom rules: Add your rules directly in this file. For example, if you want to allow incoming traffic on port 9000, you can add the following rule:
tcp dport 9000 ct state new accept
3. Save and exit: After adding your rules, save the file and exit the text editor.
4. Restart nftables rules: For the changes to take effect, reload the nftables rules with the following command:
# systemctl restart nftables.service
Best Practices:
  • Minimal exposure: Only open the ports that are absolutely necessary. This minimizes the attack surface and helps maintain a secure environment.
  • Regular review: Periodically review the ports you have opened to ensure they are still required, and close any that are no longer in use.
  • Avoid conflicting rules: Ensure that the rules you add do not conflict with existing default rules..
