Prerequisites
Warning
As of this release the implementation of the /provider endpoint for custom connector implementations is required. In case you connect to a data source via a custom connector, please make sure this endpoint is available before upgrading your installation. Contact support if you are in doubt about the implications.
- My current installed TrendMiner version is 2023.R3.0 or higher. - In case you are running on version 2023.R2.0 or older, please upgrade first to version 2023.R3.0.
- I have VM console access. - In case issues occur during an upgrade TrendMiner support might request console access to efficiently resolve these issues. In case console access is restricted by the company it is advised to prepare for a temporary access permission for efficient troubleshooting.
- I have a recent VM snapshot. - Taking a VM snapshot before an upgrade is considered mandatory. Read here why.
- I have a recent database backup. - Read here why this is important and check here how to take a backup before an upgrade.
- I have enough free disk space. - The available free disk space should be 25GB + the size of a TrendMiner backup if "Take backup before upgrade" is enabled. In case of doubt we advise to create a backup manually, check the free disk space when the backup is completed and trigger the upgrade with the option "Take backup before upgrade" disabled.
- I have updated the CentOS 7 default repository references. - Notice- This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance? - If you are using CentOS 7, you will have to update the default repository references. The following commands have to be executed as the root user: - sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
- My system meets the minimum system requirements as listed below. - Resource - Minimum - Minimum with Embedded Notebooks & Machine Learning Model functionality - Recommended - vCPU - 8 - 16 - 16 - RAM - 32GB - 64GB - 64GB - Disk space - SSD, 200GB, 250MB/s - SSD, 500GB, 250MB/s - SSD, 500GB, 250MB/s - Important- On top of the above requirements TrendMiner requires the memory to be scaled along with the CPUs at a ratio of at least 1-2 and preferably 1-4. In practice this would result in 128GB RAM for a server with 32 CPUs and 256GB RAM for a server with 64 CPUs
