TrendMiner connectivity
Time series connectivity
Tableau 3.  Supported time series connectivity
Type / vendor / historian / IoT platform
Supported versions
TrendMiner connector required
Aveva PI
PI OLEDB 2010, 2016+, 2017 R2, 2017 Enterprise
Yes
PI AF SDK 2010 R3+, 2017 R2 SP1, 2018
Yes
AspenTech IP21
v7, v8, v10, v11
Yes
GE Proficy
4.5, 5.5, 7.0 SP4, 8.1, 9.1, 2022, 2023
Yes
Yokogawa Exaquantum
2.85, 3.02, 3.10, 3.15
Yes
Honeywell PHD
R3.30, R4.00, R4.10
Yes
Aveva Wonderware
2014 R2 SP1 P02, 2017
Yes
ODBC
Yes
OleDB
Yes
SQLite
Yes
Cumulocity
ODBC connection to DataHub
Yes
Microsoft Azure Data Explorer (Kusto ADX)
No
AWS IoT SiteWise
No
Amazon Timestream
No
JDBC
postgres, mariadb, sqlite, mssql
No
CSV import
No
Write your own connector using the TrendMiner connector API
No
Context connectivity
Tableau 4.  Supported context connectivity
Supported versions
Aveva PI
PI AF SDK 2017 R2 SP1 or higher
Yes
AspenTech APRM (Aspen Production Record Manager)
12.2
Yes
AWS IoT SiteWise
No
JDBC (Context SQL Sync)
No
CSV import
No
Asset connectivity
TrendMiner supports the following options to get your asset data available in TrendMiner:
Tableau 5.  Supported asset connectivity
Supported versions
Aveva PI
Yes
12.2
Yes
AWS IoT SiteWise
No
JDBC
No
CSV import
No
Set up an Asset Framework directly via the Digital Twin Manager
No
