How to connect to Honeywell PHD?
- Install the PHD client tools on the Plant Integration server.
- Copy the PHDAPINET.dll that is part of the Client tools installation to the Plant Integrations bin folder. The default location would be: C:\inetpub\PlantIntegrations\bin
- The TrendMiner connector (plant integrations server) by default uses port 3100 and 3150 to connect to the PHD server. Make sure these ports are not blocked by a firewall and the connector can connect to these ports.
- Follow the instructions on How to connect to time series data sources?
