Bug Fixes
  • TrendHub Filters - Fixed an issue where periods on the focus chart were incorrectly filtered out when using a search-based filter that excluded everything else while zoomed in to a period containing only a partial search result.
Admin only
  • License management - Fixed an issue where the license upload button stayed disabled after a failed upload. The button now resets, so you can retry the same or a different file without refreshing the page.
  • Certificates - Fixed an issue where the SAN (Subject Alternative Name) field in the CSR generation screen was labeled "optional." Modern browsers require SAN and ignore Common Name, so the field is mandatory. The label now reflects this.
  • Fixed an issue where a failed task during an upgrade did not cancel subsequent tasks, which could cause cascading failures. Failed tasks now cancel all remaining tasks.
