Application Enhancements
  • Dashboarding
    • Open dashboards in presentation mode by default
    • Quickstart panel toggle in dashboard presentation mode
    • Optimized X-axis time ticks for narrow dashboard tiles
    • Choose target for URLs in the dashboard text tiles
    • Iframe embedding
      • Live mode button in the header
      • Support live mode query parameter
  • Work Organizer
    • Discoverable share link for easy sharing
    • Columns are resizable
    • Harmonized action dropdown menus
  • Integrations
    • Add filters for Context Views through URL parameters
  • Enhanced logging for Plant Integrations – System administrators can now view and set the log level without accessing config files directly, configure log file retention and size via API. Logs for Connector, ApiGateway, and Configurator are also centralized in Windows Event Log for easier monitoring. Note: Windows Event Log support is available for AppHost installations only.
  • Event Analytics - The End Date of search results is now hidden by default, removing a property that was redundant in most workflows. You can re-enable it whenever you need it.
  • Fingerprint monitoring - Calculated scores for fingerprint hulls and similarity searches over long periods are now more accurate, so deviation monitors detect deviations sooner.
  • Collapsed plotting - Released in 2026.R1.0 to help you focus on the unfiltered periods of the focus chart, collapsed plotting now resamples the available data when collapsing filters. Filtering out long periods no longer produces a low-resolution visualization.
  • Canary Integration - The Canary provider now supports API key-based authentication. Configuring an API key is recommended to improve performance and allow disabling anonymous authentication.
  • Proficy Historian connectivity - Extended Proficy compatibility to versions: 2024 SIM1 and higher, and 2025.
Admin only
  • Upgrade Center - File uploads can now be cancelled cleanly. Cancelling an upload removes the partially uploaded file from the server instead of leaving it on disk.
