Known Limitations
Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring, users have to refresh the chart.
External content tiles in the dashboard need cookies to properly load all content (and be able to login when required).
Scooter values may change when zooming in after adding the scooter. This is because scooters currently interpolate the data points on the chart.
When calculated tags are deleted, they cannot be created with the same name again.
After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
Notebooks can be shared with other users in the Work organizer. Without “Save-As” functionality, only the original author of notebook can make changes to the shared notebook.
ACLs are not automatically updated when renaming a data source.
Writable context types are not updated when live sync is off and historical sync hasn’t run after the change.
