Security
TrendMiner users can either exist locally or via an external Identity Provider. An overview of all users can be found under the "Security" section in ConfigHub.
The user overview shows the username, full name, email address and the identity provider. Specific users can be searched through via the top right search bar above the table.
Creating users
Usernames need to be unique and cannot be changed afterwards.
Password policy
  • Contain at least one digit
Configuring User details
From the user overview an user can be clicked to see more detail in the side-panel. Here more options can be performed such as:
  • Change passwords (local users only)
  • Delete the user from TrendMiner (local users only).
Group management allows the creation of a collection of users and other groups (i.e. nested groups). An overview of all existing groups can be found under the "Security"-section in ConfigHub.
The group overview shows the groupname and path of the groups so that it can be linked to its corresponding identity provider.
Specific groups can be searched through via the top right search bar above the table.
Creating Groups
To create a new group you will need to go to the groups-menu under the "security" section. From there groups can be added via the "+add group"-button.
Configuring Group details
From the group overview a group can be clicked to see more detail in the side-panel. Here more options can be performed such as:
  • Edit the name of a group
  • Delete the group
These actions can only be done for Local Groups. Groups synced from an external IdP are non-editable and should be managed from the IdP itself.
Warning
Deleting a group will also delete all subgroups. A modal will be shown when this is the case. In case you want to keep the subgroups you will need to remove them first from the member list.
Creating Clients
TrendMiner allows the creation of a client and secret in order to generate a token to be used in external API calls.
To create a new client you will need to go to the clients-menu under the "security" section. From there clients can be created via the "+add client"-button.
You will be asked to enter a name (client ID) for your client which will be used for external references. Once the client is created you can click on it to:
  • Edit the client ID
  • Show the secret of the client
  • Generate a new secret
  • Delete the client
Regenerating a secret will invalidate your old secret and tokens. This action cannot be undone.
Clients need to be added to a domain/entity in the Access management menu just as users/groups to allow access to the data.
Fetch Token
A token can be fetched via curl or any other means. An example is shown below.
A new token needs to be fetched when the token expires after 5 minutes.
Template:
curl --request POST \
Example:
Response token:
 "access_token":
 "expires_in": 300,
 "refresh_expires_in": 0,
 "token_type": "Bearer",
 "scope": "email profile"
  • Domain: DATASOURCE or TIMESERIES_BUILDER
  • Entity:
    • Using the DATASOURCE domain: Enter the name of the Historian Connection, as configured in TrendMiner or use "ALL" to indicate the collection of all Historian Connections).
  • Members: Users, groups or clients you want to grant access permission for the domain.
To edit an existing access permission, click on the entry you want to edit and click “Edit” in the options menu.
To remove an existing access permission, click on the entry you want to delete and click “Delete” in the options menu.
  • Private key
  • CSR for that private key
  • Certificate chain
TrendMiner only supports PEM certificates. OpenSSL can be used to convert certificates in a different format to PEM.
Once these prerequisites are fulfilled, HTTPS can be enabled via the "Action" menu on the top right.
When uploading new trusted certificates via Security - Certificates and HTTPS is enabled, SSL can be reloaded by selecting “Reload SSL” in the Actions menu of the screen.
For a more detailed guide of what is, why and how to use SSL in TrendMiner, please consult our support documents.
Certificate signing request (CSR)
Via ConfigHub a CSR can be generated.
To start, clicking the Actions menu and select “Certificate signing request”. A side panel will open to download or generate the CSR.
At the top of the side panel, you can download the CSR when it is generated on the server.
Below this section, information to generate the CSR can be provided. There are 2 options to generate a CSR, using
  • Alternative names
    With this option, it is allowed to provide alternative fully qualified domain names to be protected using the certificate. These are optional, the server name of the installation is the primary domain used.
  • Wildcard
    This options allow for HTTPS on all subdomains of the provided wildcard domain. This domain is required.
When no private key is available yet, one will be generated. Uploading a new private key, might break current HTTPS/SSL and pending Certificate signing requests (CSR).
Detailed information on identity providers can be found here.
Detailed information on the ConfigHub password config can be found here.
