How does TrendMiner determine tag type?
When using a supported TrendMiner connector, the tag types and interpolations used in the historian will be converted to one of the tag types supported by TrendMiner.
For ODBC/OleDB/SQLite data sources, the tag type mapping can be configured as explained in the linked articles.
For other connectivity options to common data historians TrendMiner uses the type mappings as listed in the tables below:
  • Aveva Pi
    Historian Type
    Mapped TrendMiner Tag Type
    OLEDB D, SDI PIPointType.Digital
    DIGITAL
    OLEDB S, SDI PIPointType.String
    STRING
    OLEDB others
    ANALOG
    SDK point.IsDiscrete
    DISCRETE
  • IP21
    A special query is executed when using the plug-&-play connector that gets information if interpolation type is stepped and information regarding the value’s ‘display length’. Given this, TrendMiner will assign any one of the supported tag types.
  • Aveva Wonderware
    Historian Type
    DoubleByteString, SingleByteString, Event, Structure
    STRING
    Double, Float
    ANALOG
    Considering RawType (Int1, Int2, Int4, UInt2, UInt4) and TagInterpolationType property
    DISCRETE or ANALOG
  • GE Proficy
    Historian Type
    FixedString, VariableString, Time
    STRING
    Bool
    DISCRETE
    Considering StepValue (true or false) property
    ANALOG (false); DISCRETE (true)
  • Exaquantum
    Historian Type
    String
    STRING
    Integer/long and discrete aggregation
    DISCRETE
    Others
    ANALOG
  • PHD
    Historian Type
    U (unicode)
    STRING
    C (char)
    STRING
    I (integer)
    DISCRETE
    L (long)
    DISCRETE
    Others
    ANALOG
