Prerequisites
My current installed TrendMiner version is 2022.R2.0 or higher.
In case you are running on version 2022.R1.0 or older, please upgrade first to version 2022.R2.0.
I have VM console access.
I have a recent VM snapshot.
I have a recent database backup.
I have enough free disk space.
My system meets the minimum system requirements as listed below.
Resource
Minimum
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk space
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
All connectors are running on a Windows server with Microsoft .NET 4.8 or higher installed.
As of connector version v4.13.0 the required .NET version is 4.8, compared to .NET 4.5.2 for previous releases.
