Synopsis
Tag dependencies
All calculated tags in TrendMiner are shared by default. If a user has access to all underlying tags, the calculated tag can be used as well. It was, however, not possible to verify the definition of these tags, unless they were explicitly shared through the work organizer. This made it difficult to assess their value or correctness and often led to the creation of multiple, similar tags.
The tag dependencies browser addresses this issue by allowing you to browse the details of the mapped variables and their underlying tags. The tag dependency browser can be accessed on the summary screen of a calculated tag and in the creation screen of a Formula, Aggregation and Machine learning model tags.
When opening a calculated tag through the Work Organizer, the complete definition of the calculated tag is shown. The full details of all dependencies can be assessed in the variable mapping section, which is available for all calculated tags.
The symbol in front of every variable indicates the type of tag. Clicking the symbol will add the variable to the focus chart. Clicking anywhere else within the field of a specific variable will open its details in the tag dependency browser.
In case a calculated tag has been built upon other calculated tags, the dependency browser allows you to navigate the complete dependency tree by using the breadcrumbs. On every level, the variable mapping section can be used to add the corresponding tag to the focus chart.
Schedule Manager
The Schedule Manager functionality allows you to create and configure schedules that best fit your needs. You can do that from the Platform Configurations menu in ContextHub. Schedules are defined based on a multiple user configurable options:
- Timezone
- Workweek Start day
- Number of days in the Workweek
- Start time
- Shift duration
Multiple schedules are supported and can be managed from the Platform Configurations menu in ContextHub.
Once a schedule is configured it allows you to filter data in DashHub based on a timeframe defined by a shift from a specific schedule.
Context grid actions menu
Right click actions are now available on a cell in the grid (table view) in ContextHub.
- There are two options available: - Copy value – copies cell value to clipboard.
- Add filter – adds a filter to your currently opened view with a prepopulated value from the selected cell.
Homepage image and message expiration
New options to brand the homepage with an image of your choosing and to set an expiration date for the specified message are now available. Those options can be configured through the Homepage configuration selection in ConfigHub.
You can optionally specify an image to appear in the administrative message tile either by drag and drop or by manually selecting an image from your file system.
The option to set an expiration date for the administrative message is now also available.
Contact information, if specified, will always be shown irrespective of whether an expiration date is configured or has passed.
