Patch Release Updates
4.59.17 (connector patch)
Fixes an issue where the 'Test connection' always failed (also for successful connections) when adding a new PI AF or APRM data source in ConfigHub.
2023.R4.0-11
Fixes an issue preventing the direct upgrade from 2023.R4.0 to 2024.R1.1. Customers who want to upgrade from 2023.R4.0-07 or lower to 2024.R1.1 should either upgrade to 2023.R4.0-11 or to 2024.R1.0 first.
Fixes an issue with a failing LDAP sync if the sync took longer than 5 minutes. Customers who experience LDAP sync issues are advised to patch.
Fixes several issues in ContextHub which can lead to performance degradation, components for context item creation as part of a monitor alert being deselected or failing ContextHub view exports. All customers who actively use ContextHub are advised to patch.
4.59.16 (connector patch)
Fixes an issue where PHD timestamps were shifted based on the wrong timezone, leading to missing data in TrendMiner. customers with a connection to a PHD historian should upgrade their connector.
2023.R4.0-07
Fixes an issue where in some cases IP21 tags could not be visualized on the chart. Customers with IP21 data sources are advised to patch.
Fixes a data management discrepancy between the asset tree builder and the asset CSV import which allows working with both interchangeably.
2023.R4.0-06
Fixes a critical issue with an internal certificate. All customers must patch their installation to prevent unexpected downtime. Note that this issue does not pose a security risk.
4.59.15 (connector patch)
