Known Limitations
- Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring users would have to refresh the chart.
- Embedding TrendMiner in external applications is limited to Microsoft Teams. Extensions to improve this functionality and make it more robust will come later.
- External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
- Scooter values may change when zooming in after adding the scooter. This is because scooters currently interpolate the data points on the chart.
- When calculated tags are deleted, they cannot be created with the same name again.
- After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
- The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
