Prerequisites
Tipp
After upgrading to TrendMiner version 2023.R3.0, part of the ConfigHub functionality will be moved to Edge Manager, a new interface for system and network administrators to keep your installation healthy and up-to-date. Refer to Edge Manager for the services health overview, diagnostics (downloading log files), future upgrades (including hotfixes) and general network settings. Information on how to access Edge Manager can be found here.
My current installed TrendMiner version is 2023.R2.0 or higher.
In case you are running on version 2023.R1.0 or older, please upgrade first to version 2023.R2.0.
I have VM console access.
I have a recent VM snapshot.
I have a recent database backup.
I have enough free disk space.
I have updated the CentOS 7 default repository references.
Hinweis
This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance?
sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
My system meets the minimum system requirements as listed below.
Resource
Minimum
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk space
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
