Known Limitations
  • Embedding TrendMiner in external applications is limited to Microsoft teams. Extensions to improve this functionality and make it more robust coming later.
  • External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
  • The Jupyter notebook files and output objects are not backed up automatically by TrendMiner in this release. You can recover them from your VM (Virtual Machines) snapshots or upload them via the ‘import’ function.
  • Notebooks can be shared with other users, using the work-organizer. All shared users have edit rights and the most recent change is saved. However, as there is no live update or collaboration modus, working with 2 users on the same notebook at the same time can result in undesirable behaviour.
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
