Patch Release Updates
2023.R1.0-18
Fixes an issue that led to a failed TrendMiner upgrade when a large Asset Framework permission set is in place.
2023.R1.0-15
Fixes an issue where the service responsible for indexing could frequently restart due to high load, causing general performance degradation. We advise all customers, and especially the larger setups to upgrade.
2023.R1.0-14
Fixes an issue where opening a dashboard with many TrendHub view tiles can cause an overload for the plotting and indexing service causing performance loss or crashes. Customers with dashboards with many TrendHub view tiles are advised to patch their installation.
2023.R1.0-13
Fixes an issue where in some cases extra memory is no longer assigned to the plotting and indexing service, which can lead to performance degradation. All installations with >32GB RAM assigned to TrendMiner are advised to patch their installation.
2023.R1.0-18
Fixes an issue where tag permissions are no longer cached which can lead to degraded performance, slow tag searches and restarts of the security service. Customers experiencing these issues are advised to patch their installation.
2023.R1.0-20
Includes vertical scaling of memory for the data source service which implies that if the system memory resources are higher than the minimal system requirements more memory becomes available for the service which connects to data sources. Customers with a high number of data sources and a high number of tags can benefit from this improvement.
2023.R1.0-21
Fixes an issue which can render the TrendMiner installation unstable in case your installation has more vCPU's then minimally required. All customers with more then 8 vCPUs who experience instabilities are advised to patch their installation.
