Warning
Security recommendation
To ensure secure communication between TrendMiner and your data sources, we strongly recommend enabling security features for the connector. This includes:
HTTPS/SSL encryption to protect data in transit. Learn how to enable HTTPS/SSL: How to enable HTTPS/SSL connection to the Connector?
Basic Authentication to restrict access to authorized users. Learn how to enable Basic Authentication: How to enable basic authentication for the connector?
Enabling these features helps prevent unauthorized access and protects sensitive data from interception.
Resource | Amount |
vCPU | 2 |
RAM | 2GB |
Disk Space | 5GB |
One of the following OS's: Windows Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022, Windows Server 2025, Windows 10, Windows 11
IIS 7 or higher
.NET Framework 4.8 or higher
IIS Web Deploy 3.5 or higher
For Aveva PI: the PI AF SDK drivers provide good connection pooling and efficient transfer. The Plant Integrations and historian need not be co-located.
For other historians, TrendMiner recommends installing Plant Integrations on the historian server, as their drivers are normally firewall-unfriendly or latency-sensitive, mostly using DCOM. Experience tells us that an installation on the historian server leads to a better performance than installations that simply use the same network.
