Local custom S3 backup/restore
Perform a full system backup/restore for easier migration, securely stored on your own custom S3 deployment (MinIO or others), which might provide local, on-premise options.
This migration solution requires the setup of an AWS S3 API (v4) compatible storage location. MINIO is a natively supported option.
Setup of these storages is out of TrendMiner scope
This migration solution is available as of the 2024.R2.1 release. In case the remote backup/restore using Azure Blob Storage or AWS S3 is not a viable option for you we recommend using the local custom S3 backup/restore migration.
More info on both options:
Configuring your Minio S3 solution in Edge Manager
you have a running Minio installation that can be used for backup of your TrendMiner installation.
you have the following credentials information to configure TrendMiner Backup provider with the proper permissions.
URL (in case of https, only public certificates are allowed.)
Bucketname
Access Key
Secret Key
Login to TrendMiner EdgeManager
https://url/edge or http://url:8080 (in case no valid certificate is installed)
Click “Sign In”
Navigate to “BACKUP AND RESTORE”->Remote
Click on Full
Click on Storage Settings
Select Minio in the drop down menu called “Provider”. After selecting the storage provide you need to fill in all information required, as shown in the screenshot below.
You should have all the parameters for configuring, except for the backup path.
Wait until storage location is validated
you can click on Storage Settings tab, to refresh the page
The status should say Available before continuing with the next steps.
In case the status is as following
Tip
In case something is going wrong (Status stays on Unavailable), these are some tips you can try to fix
make sure the date and time are correct on the server. Also NTP server need to be in place. Not setting it, will result in authentication failure for the backend tooling used to setup the remote storage
Doublecheck all parameters provided.
Validate you can properly communicate to Minio S3 from the TrendMiner Host.
In case all parameters are properly set, and it still doesn't work, please try to use a S3 client (E.g. FilezillePro https://filezillapro.com/) that you can run on your Laptop/Desktop to try to access the Storage Account, to fully validate the parameters.
In case all above is not helping, please contact TrendMiner Support.
Configuring your Custom S3 provider in Edge Manager
you have a AWS S3 API(v4) compatible storage provider setup or use one of the available cloud S3 compatible storage providers.
Bucketname
Access Key
Secret Key
Click “Sign In”
Click on Full
Select Custom S3 in the drop down menu called “Provider”. After selecting the storage provide you need to fill in all information required, as shown in the screenshot below.
Tip
Not all of the S3 compatible solutions are providing the Region parameter. If the Region is not available, you can pick a name you prefer, e.g. customs3region or leave it empty
Tip
Validate you can properly communicate to S3 from the TrendMiner Host.
