Creation and configuration of the new TrendMiner server
The first step in the OS migration process is to set up a new TrendMiner appliance based on the new RHEL9/AlmaLinux 9 OS.
TrendMiner still provides the same deployment options as before and also the installation process is similar as before. All info and a comparison of the different deployment options can be found in our installation guide.
Also the instructions on how to install a new TrendMiner appliance can be found in this installation guide.
Before starting the installation of the new server, please carefully read the following important notes:
  • The new TrendMiner server does not have to use the same deployment method as the current one. This means it is possible to switch to virtual appliance, single node or SaaS deployment after the OS migration without additional complications.
    For existing SaaS customers and customers who switch to a SaaS contract after the OS migration, the migration will be executed by TrendMiner as part of the SaaS agreement.
    Technically it is possible to reuse the existing server and migrate 'in place' but this approach is not advised and therefor not documented. More details can be found in our migration FAQs.
  • For the 2024.R2.0 the system requirements will change. Please make sure to set up the new server following the new system requirements:
    Resource
    Minimum
    Recommended
    Important notes
    vCPU
    16
    + 1 core per 4 active kernels (per user) + 1 core per 8 notebook tiles (per user per dashboard)
    16
    For servers with high indexing activity, the available CPU's should at least match the configured simultaneous indexing threads.
    RAM
    64GB
    + 1GB per active kernel (per user) + 256MB per notebook tile (per user per dashboard)
    96GB
    As of version 2024.R3.0 an additional 32GB of RAM will be required. We would strongly encourage to already provision this additional memory when setting up the new server.
    Disk space
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
    Slow disks may heavily impact the user experience or lead to failures. We would strongly suggest to double check the disk speed using the Linux commands provided here: Prepare the Installation
  • For the final step of the OS migration the current and the new server will need to run on exactly the same TrendMiner version, including the patch number, e.g. 2024.R2.0-04.
    If the new server was installed with TrendMiner version 2024.R2.0-04 and the current production server is upgraded with a newer 2024.R2.0-05 it will not be possible to restore the backup from the old server on to the new server until the new server is upgraded to 2024.R2.0-05.
  • Since a backup will be restored on the new server not all configuration steps from the installation guide are required for the OS migration. The following config steps can be omitted:
    • Uploading a license: the old license will be transferred automatically to the new server.
    • Connectivity and access management: configured data sources will be migrated automatically to the new server or can be updated as a post-migration step if needed.
    • Connector/Plant Integration installation: after the migration it will be possible (and advised) to connect to the already installed connector(s).
    • User management: configured IDPs will be migrated automatically to the new server or can be updated as a post-migration step if needed.
    All other configuration steps (SSL configuration, NTP configuration, ... ) should be executed following the installation guide.
  • After the installation, validate that all services are running. Go to ‘Services’ page under DASHBOARD in EdgeManager and confirm all services show a green status.
  • For the new server at least the same amount of disk space should be reserved. In case the disk was running full on the old server we would suggest to take this opportunity to add additional disk space on the new server.
  • In case your current installation has custom K3S IP addresses configured, these custom IP addresses need to be configured again manually BEFORE the installation of the TrendMiner software (as also instruction in the installation guide). If in doubt, please contact TrendMiner support.
