Simple use cases
This page contains some simple use cases that will help you apply TrendMiner in your day-to-day work. These use cases consist of a minimal number of steps, are easy to replicate and can be applied to a wide range of processes.
1. Comparing today's process behavior to last week's 1 minute  | 2. Check recent process behavior 1.5 minutes  | 3. Get easy access to frequently used tag sets 2 minutes  |
4. Smoothing noisy signals 1.5 minutes  | 5. Calculating a derivative 1 minute  | 6. Calculating daily production 2 minutes  |
7. How often did this behavior occur? 2 minutes  | 8. Report on monthly averages 4 minutes  | 9. Filter out unstable behavior 2 minutes  |
10. Monitor on process thresholds 1.5 minutes  | 11. Monitor on similar process behavior 1.5 minutes  | 12. Set up a monitoring dashboard 1.5 minutes  |
