Known Limitations
Embedding TrendMiner in external applications is limited to Microsoft teams. Extensions to improve this functionality and make it more robust, will arrive later.
External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
Scooter values may change when zooming in after adding the scooter. This is because scooters currently interpolate the data points on the chart.
When calculated tags are deleted, they cannot be created with the same name again.
After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
