Warnung
Gefahr
It is not recommended to use the "set notruncation;" option in your queries, as this will remove any restriction in the number of data points returned in each request. In extreme cases, this could cause TrendMiner services to go out of memory. It can be useful to add this option for initial testing, but do not use it in production to avoid sudden issues.
ConfigHub configuration
Type name of data source, select “Microsoft Azure Data Explorer” from the Provider dropdown. Selecting the capabilities for the data source with the given checkboxes will open additional properties to enter, grouped in following sections:
Connection details – lists properties related to the configuration of the connection that will be established with Microsoft Azure Data Explorer.
Time series configuration – lists properties relevant for the timeseries data.
“Provider” - select the option Microsoft Azure Data Explorer from the dropdown.
“Capabilities” - the only capability supported is the Timeseries capability. Select the checkbox.
"Cluster" - to be mapped with value of the cluster URI.
https://<cluster>.<region>.kusto.windows.net
"Application ID" - a mandatory application id. In Azure a new application “TrendMiner” needs to be registered. After completion of this registration the application id will be available. For more info please refer to Azure Active Directory application registration or consult with the Azure Data Explorer documentation.
"Tenant ID" - a mandatory tenant id. In Azure a new application (TrendMiner) needs to be registered. After completion of this registration the tenant id is available.
"Client secret" - after registration of the TrendMiner application in Azure a client id and a secret need to be generated in order to get application access. The client secret for this access needs to be entered here.
"Database" – to be mapped with the name of the ADX database holding the time series data to be pulled.
“Index query” - a query used by TrendMiner to ingest timeseries data for a specific tag. The query is expected to return a ts (timestamp) and a value. The following variables are available to be used in the WHERE clause of this query. The variables will be substituted at query execution with values.
“Internal plotting” - if this option is selected TrendMiner will use interpolation if needed to plot the timeseries on the chart on specific time ranges. If this value is not selected and no plot query was provided, TrendMiner will plot directly from the index.
“Plot query” – a query used by TrendMiner to plot timeseries data for a specific tag. The query is expected to return a ts (timestamp) and a value. The following variables are available to be used in the WHERE clause of this query. The variables will be substituted at query execution with values.
{STARTDATE}. TrendMiner will plot data per intervals of time. This denotes the start of such an interval.
{ENDDATE}. TrendMiner will plot data per intervals of time. This denotes the end of such an interval.
customTypeA;ANALOG
customTypeB;DIGITAL
customTypeC;DISCRETE
customTypeD;STRING
Example queries
To create a simple. working set of tables with the schemas used in this documentation, the following queries can be executed. Note that this considers data entered as strings in the tables, even though they might represent numeric values (e.g. "5.01").
.create table MetaData (['id']: string, name: string, description: string, ['type']: string, units: string) .create table Data (['id']: string, ts: datetime, value: string) .create table DigitalStateData (['id']: string, intValue: long, stringValue: string)
The index query for this simple example selects the data based on the parameters {ID}, {STARTDATE}, and {ENDDATE}. TrendMiner will fill in these variables when sending the query to ADX. Note that this query does not perform any analytics optimization or interpolation. It will simply return all rows that match the conditions. Due to the data schema (the value was defined as string type), this query works for ANALOG, DIGITAL, and STRING tags.
Data | where ts between (datetime('{STARTDATE}') .. datetime('{ENDDATE}')) | where id == '{ID}' | project ts, value| order by ts asc
The plot query will be the same as the index query in this simple example. Once again, all rows that match the conditions will be returned without any further processing.
To map STRING values to a numeric value (to define the TrendHub y-axis plotting order), the following digital states query can be defined.
DigitalStateData | where id == '{ID}' | project stringValue, intValue
Example 2 - Extended configuration
.create table MetaData (['id']: string, name: string, description: string, ['type']: string, units: string) .create table Data (['id']: string, ts: datetime, value: decimal) .create table StringData ( ts: datetime, id: string, value: string) .create table DigitalStateData (['id']: string, intValue: long, stringValue: string)
let StringValuesQuery = view() { StringData | where id == '{ID}' | where ts between (datetime('{STARTDATE}') .. datetime('{ENDDATE}')) | order by ts asc | where isnotempty(value) | project ts, value }; let NumericValuesQuery = view() { let _Data = Data | where id == '{ID}' | where ts between (datetime('{STARTDATE}') .. datetime('{ENDDATE}')) | where isnotempty(value) | project ts, value | order by ts asc; let MyTimeline = range ts from datetime('{STARTDATE}') to datetime('{ENDDATE}') step {INDEXRESOLUTION} * 1s; MyTimeline | union withsource=source _Data | order by ts asc, source asc | serialize | scan declare (i_min:decimal, i_max:decimal, i_minTs:datetime, i_maxTs:datetime, startValue:decimal, endValue:decimal, startTs:datetime, endTs:datetime, min:decimal, minTs:datetime, max:decimal, maxTs: datetime) with ( step s1 output=none: source=="union_arg0"; step s2 output=none: source!="union_arg0"=> startValue = iff(isnull(s2.startValue), value, s2.startValue), startTs = iff(isnull(s2.startTs), ts, s2.startTs), i_min = iff(isnull(s2.i_min), value, iff(s2.i_min > value, value, s2.i_min)), i_minTs = iff(isnull(s2.i_min), ts, iff(s2.i_min > value, ts, s2.i_minTs)), i_max = iff(isnull(s2.i_max), value, iff(s2.i_max < value, value, s2.i_max)), i_maxTs = iff(isnull(s2.i_max), ts, iff(s2.i_max < value, ts, s2.i_maxTs)); step s3 output=none: source!="union_arg0" => i_min = iff(isnull(s3.i_min), value, iff(s3.i_min > value, value, s3.i_min)), i_minTs = iff(isnull(s3.i_min), ts, iff(s3.i_min > value, ts, s3.i_minTs)), i_max = iff(isnull(s3.i_max), value, iff(s3.i_max < value, value, s3.i_max)), i_maxTs = iff(isnull(s3.i_max), ts, iff(s3.i_max < value, ts, s3.i_maxTs)); step s4: source=="union_arg0" => startValue=s2.startValue, startTs=s2.startTs, min = s3.i_min, minTs = s3.i_minTs, max = s3.i_max, maxTs = s3.i_maxTs, endValue= s3.value, endTs= s3.ts; ) | project startTs, startValue, endTs, endValue, minTs, min, maxTs, max | mv-expand ts = pack_array(startTs, minTs, maxTs, endTs) to typeof(datetime), value = pack_array(startValue, min, max, endValue) to typeof(string) | order by ts asc | where isnotempty(value) | project ts, value }; let type = toscalar(MetaData | where id == '{ID}' | project type); union (StringValuesQuery() | where tolower(type)=='string'), (NumericValuesQuery() | where not(tolower(type)=='string')) | where isnotempty(value)
let StringValuesQuery = view() { StringData | where id == '{ID}' | where ts between (datetime('{STARTDATE}') .. datetime('{ENDDATE}')) | order by ts asc | where isnotempty(value) | project ts, value }; let NumericValuesQuery = view() { Data | where id == '{ID}' | where ts between (datetime('{STARTDATE}') .. datetime('{ENDDATE}')) | where isnotempty(value) | project ts, value=tostring(value) | order by ts asc; }; let type = toscalar(MetaData | where id == '{ID}' | project type); union (StringValuesQuery() | where tolower(type)=='string'), (NumericValuesQuery() | where not(tolower(type)=='string')) | where isnotempty(value)
