Overview
Plant Integration configuration on the connector side which consists of creating necessary files on a specific location.
Creation of specific queries and configuration elements that will fetch the data in the right format for TrendMiner to digest
Adding the data source on the client-side from the TrendMiner ConfigHub page.
Create folders
First step is to browse to the Plant Integration folder you have created during installation. This folder will most likely reside inside the inetpub folder on the c drive of your connector server, which is the default location:
c:/inetpub/PlantIntegrations
Create a folder (not case sensitive) that will host all your ODBC/OLEDB/SQLite configuration files. All configuration files for ODBC connections will go into the ODBC folder, for OLEDB connections into the OLEDB folder and so on.
Create a subfolder for each data source you want to configure inside the correct ODBC/OLEDB/SQLite folder, depending on which connection type you are using. In the following example we will configure an ODBC data source called “Plant_LIMS”, so we create the "Plant_LIMS" subfolder in the recently created "ODBC" folder.
Create Configuration files
Create the following configuration files needed to configure the generic data sources.
For ODBC/OLEDB:
For SQLite:
File name and type
Description
Required / Optional
sqlite.db (only for SQLite)
Required
connection.txt
Required
list.sql
Required
values.sql
Required
values-STRING.sql
Query select statement that returns the timestamps and values for a given string tag. Only include if necessary. If any string tags aren’t in the same database you could use the query here or decide to join with your values.sql query.
Optional
type.csv
Optional
datetime_format.txt
Optional
timezone.txt
Optional
Connection.txt file
ODBC example:
Driver={ODBC Driver 13 for SQL Server};Server=<ipAddress,port>;Database=<database_name>;Uid=<myUsername>;Pwd=<myPassword>;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;As a minimum requirement, you shall specify the Server, Database, Uid, and Pwd.
OLEDB example:
SQLite example:
Set up a new System Data Source using the corresponding SQL Server driver.
Once the System Data Source is configured, create a “connection.txt” file and make reference to the System Data Source as shown below.
Configuring the queries
The data contained in your datasource now needs to be fetched in a way that TrendMiner can understand to correctly digest and present back to the end users. There are a few steps required to make this work.
The first step is a query that will return unique tagnames (to identify the time series), its datatype, and optional metadata such as description and units. This query goes into the list.sql file.
The second step is a query that will return an ordered series of timestamp and value pairs for a given tagname, start date, and end date. This query goes into the values.sql file.
The third step is to map any custom datatypes to the TrendMiner datatypes. This mapping goes into the type.csv file. This step is optional and only required if the datatypes returned in step 1 don't already map to the TrendMiner datatypes.
The fourth step is to configure the returned timestamp format from step 2 so TrendMiner can parse it correctly. This step is optional and only required if the timestamp format returned in step 2 is not "yyyy-MM-dd HH:mm:ss.fff”
The fifth step is to configure the timezone of the returned timestamps from step 2 so TrendMiner can align it correctly. This step is optional and only required if the timestamps returned in step 2 are not in UTC. This is also important to correctly handle Daylight Savings Time (DST).
list.sql query
The list.sql file will contain a SQL SELECT statement and shall return all the tags with additional metadata as shown below. If the “type” property doesn't return one of the supported tag types, you shall generate your own mapping with the type.csv file.
SELECT
tagname, description, units, "analog" as type
FROM Table_1A correct output of the query is shown below:
values.sql query
The columns returned should be named "ts" (for the timestamp) and "value". Timestamps should be in ascending chronological order, meaning oldest first, newest last.
All timestamps that are returned should fall inside the requested time interval. If they don't, then indexing will fail later on.
The complete response should be returned within a reasonable timeframe. Typically recommended is +- 1 second per month of data, with user experience noticeably dropping off when response time exceeds 5 seconds per month of data. The response time can be influenced somewhat by tweaking settings such as the index granularity in ConfigHub, although a slow datasource will always lead to bottlenecks, no matter the settings. Check the user documentation for more info.
An acceptable amount of data points within the given timeframe. The number of data points returned can be influenced by tweaking the query, or by tweaking settings such as the index granularity setting in ConfigHub. Check the user documentation for more info.
SELECT
ts, value
FROM Table_1
WHERE tagname = ? AND ts IS BETWEEN ? AND ? ORDER BY ts ASCAn example of the correct output is shown below.
type.csv mapping
In case the types returned in the list.sql file aren’t part of the ones supported by TrendMiner, you need to generate your own mapping. It is best practice to explicitly map each possible type returned by list.sql to one supported by TrendMiner. If this is not done, it can lead to confusion about why data values are interpolated in a certain way.
In the type.csv file, create one line per data type, with the output of the list.sql types as the first value, followed by a semicolon (";"), followed by one of the supported datatypes in TrendMiner. The example below ensures the results are returned in the right case, and a string result is explicitly returned as a DIGITAL result.
Without timezone (UTC) | MM/dd/yyy HH:mm |
DDMMYYY HH:mm:ss | |
With timezone | yyyy-MM-ddTHH:mm:ssZ |
yyyy-MM-ddTHH:mm:sszzz |
timezone.txt configuration
Timezone |
Eastern Standard Time |
Pacific Standard Time |
Central Europe Standard Time |
When the database stores date/times in a timezone which uses DST but the timezone is not stored along with the date/time then a 1 hour gap in the data will occur when entering summer time and 1 hour of data may be discarded when entering winter time.
The “Host” name shall be the name of the folder previously created containing all the configuration files as in the example below. The data source name is free to choose.
TrendMiner will consider the username and password provided in the “connection.txt” file and not the one provided through the interface. You do not need to provide the username and password here.
