Patch Release Updates
4.105.10 (connector patch)
  • Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
  • Fixes an issue causing a PI AF to be synced only partially.
2025.R1.0-11
  • Fixes a stability issue for large installations which was causing some services to restart frequently.
  • Mails from Cron Daemon to TrendMiner virtual appliance admins with error "No such file or directory" are no longer sent.
  • Fixes a bug where the context sync scheduler seizes to schedule new background sync tasks. It could happen that background jobs like a nightly cleanup or a historical sync were staying in the WAITING state indefinitely. This should now be resolved.
4.105.8 (connector patch)
  • Fixes a connection issue for Exaquantum data sources.
2025.R1.0-09
  • Fixes an issue where basic auth could break for connections to the connector.
  • Fixes an issue where Asset CSV import could fail if assets where created via the API but deleted via CSV import before.
  • Prevents EF live sync from auto re-enabling daily after disabling manually.
  • Fixes an issue with pagination that prevented enabling live sync when more than 20 data sources were present.
  • Fixes an issue where suggested types in context item creation were not shown when not in first page of type results.
  • Fixes context type dropdowns not showing correctly for some asset-specific types.
2025.R1.0-07
  • Fixes an issue where password change did not work.
  • Lowers the memory requirement threshold to avoid installation failures on AWS.
  • Fixes several issues with ContextHub caused by a high amount of context item types.
  • Contains an improvement which avoids unexpected application behavior caused by high database load during the EF live sync startup.
2025.R1.0-06
  • Fixes an issue with service deployment which causes upgrades to fail.
  • Fixes an issue where sometimes DashHub tiles don't load (they keep spinning).
  • Fixes an issue where mails were sent to admins about a background log cleanup process.
4.105.5 (connector patch)
  • Fixes an issue where tags from an ODBC data source can go to index status 'out-of-date'.
  • Contains an improvement which prevents a PI AF asset sync from stop the asset sync when encountering an unsupported attribute. Unsupported attributes are ignored during the AF sync.
2025.R1.0-05
  • Fixes an issue where services were not properly started after a reboot or an upgrade.
  • Fixes an issue where context item workflow names where limited to 64 characters.
