Known Limitations
  • Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring, users have to refresh the chart.
  • External content tiles in the dashboard need cookies to properly load all content (and be able to login when required).
  • Groups created in the active tag list may break when modifying the scatter plot grid by selecting a different tag from the legend dropdown.
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible, these are visible in EdgeManager.
  • Notebooks can be shared with other users in the Work organizer. Without “Save-As” functionality, only the original author of notebook can make changes to the shared notebook.
  • ACLs are not automatically updated when renaming a data source.
