Step 2: Install
The TrendMiner Virtual Appliance is a complete virtual machine that contains the infrastructure to run TrendMiner, the TrendMiner Server, which is the heart and soul of the TrendMiner installation. It contains all algorithms, runs all calculations, and serves the Graphical User Interface to the end users and admins to interact with the software. TrendMiner pre-configures the Virtual Appliance to conform to various industry standards related to security including:
Operating System patches are included with each TrendMiner update
A firewall is enabled to limit network access
SELinux is enabled in Enforcing mode
TrendMiner services run isolated in pods
The TrendMiner Virtual Appliance provides a management interface to configure the infrastructure. Operational concerns can be configured here. Basic level monitoring is included in the Virtual Appliance. Mail alerts will be sent to a configurable mail address when the available disk space is less than 20% or when critical application components fail.
Required input to complete a Virtual Appliance install includes:
IP address and netmask
Network gateway
DNS servers: name resolution of other services
Other prerequisites:
More information and frequently asked questions about the IP addresses/ranges can be found here: Appliance IP requirements FAQs
The installation of TrendMiner as a virtual appliance consists of 3 consecutive steps:
