Known Limitations
Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring, users have to refresh the chart.
External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
Scooter values may change when zooming in after adding the scooter. This is because scooters currently interpolate the data points on the chart.
When calculated tags are deleted, they cannot be created with the same name again.
After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible, these are visible in EdgeManager.
The Jupyter notebook files and PMML models are not backed up automatically by TrendMiner in this release. On-premise migrations are still to be done manually by customers by downloading the PMML models and then uploading them on the new system. This is not the case for customers migrating from Azure to AWS with Cloud Storage where back-up is done automatically with Velero.
Notebooks can be shared with other users in the Work organizer. Without “Save-As” functionality, only the original author of notebook can make changes to the shared notebook.
