Bug Fixes
Fixed an issue where the export of value based search results failed if the search definition contained a condition to find all states of a digital/string tag, and the tag has a lot of states. The definition of this search was too big to be exported to Excel.
Fixed an issue where unsubscribing to monitor alerts did not work if capitals were used in the email address configured in the monitoring notification.
Fixed an issue where importing an asset structure in CSV format, containing empty spaces or lines at the end of the file would result in errors and an unsuccessful import.
Previously, when a user selected a subfolder as location for publishing notebook pipeline in MLHub, it was published in 'My work' folder instead. This bug is fixed now and pipelines are published in the correct folder.
Fixed an issue where the CSV import failed when importing context items for an asset that did not have any yet.
As of 2024.R2.1
Fixed an issue where the indexing of ML tags failed because of special characters in the tag name.
Fixed an issue where filtered search results were not immediately reflected on the axis in the parallel coordinates plot, requiring tab switching to update.
Improved scrolling behavior when some notebook outputs are shown or a cell is added.
