Opening additional firewall ports
TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22), http(s) (tcp/80, tcp/443) and port 8080 are allowed.
    "allow_icmp": true,
    "open_tcp": [
         5666,
         10050
} In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
python -m json.tool < /etc/ansible/facts.d/iptables.fact
cd /mnt/data/ansible-playbooks ansible-playbook agent/configure-tm-agent.yml -i /var/www/dsquare-appliance/hosts
The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
- Node Exporter exports OS level metrics
- Postgres Exporter exports database metrics
- Each TrendMiner service exports JVM metrics
- Several TrendMiner services export application specific metrics
scrape_configs:
  - job_name: federated-trendminer
     honor_labels: true
     honor_timestamps: true
     scrape_interval: 15s
     scrape_timeout: 10s
     metrics_path: /federate
     static_configs:
       - targets:
           - <my-trendminer>:9100 AlertManager can then handle alerts:
groups:
  - name: TrendMiner rules
    rules:
      - alert: instance_down_2m
        for: 2m
        labels:
          severity: Critical
        annotations:
          description: TrendMiner DOWN for 2 minutes
          summary: TrendMiner DOWN
