Plant integration (connector) logs
Logging
Changes should be performed in NLog.config inside Plant Integrations website folder.
Logging archives rotation/size
By default logs are rotated at when they reach 10Mb and a maximum of 4 files are kept.
This values can be changed by editing the NLog.config file
Attributes that can be changed
archiveAboveSize
Specifies the size in bytes that the log file will be rotated
Default: 10000000
maxArchiveFiles
Specifies the number of archive files
Default: 3
Log Level
Changing the log level can be done using the API at /api/log or by changing directly the configuration files.
Open the NLog.config and change the rule for logger "*" with one of the following settings:
Level
Description
Error
Only show error messages
Warn
Show Error and Warning messages. Default setting
Info
Show Info, Warning and Error messages. Shows all requests to Plant Integration and how long they took
Debug
Show Debug, Info, Warning and Error messages. Can be very verbose. It has important information for debugging purposes
Trace
Show all log messages. Can be very extremely verbose. Logged information can have points data.
e.g.:
<rules>
      <logger name="*" minlevel="Info" writeTo="logfile" />
</rules>
Trace Tag
Specific tag can be traced to analyse process of getting data using processed points output and easier to reproduce steps using logged request and queries. This is designed to log all information with minimum debug level output to ensure that trace information would be logged even after IIS pool is reset and logging level is sufficient for tracing. It is required for long term tracing and minimising useless logged information when problem is not consistent and occurs for specific tags.
Parameter
Description
ParameterDescriptiontrace.tags
Defines comma separated tag names for which detailed information would be traced.
e.g. BA:LEVEL.1,BA:CONC.1
Currently logs all requests for traced tag and outputs type definition, data query and points for OsiSoft PI OLEDB provider.
