Historian Connector
Although no hard requirement we advise to first upgrade all connectors which are connected to the appliance to ensure connectivity continuity after the appliance is upgraded.
The advised connector for TrendMiner version 2023.R1.0 is v4.13.0 or higher.
Note: TrendMiner Plant Integrations version 4.13.0 and above is compiled with Microsoft .NET Framework 4.8. To install the updated version, the Windows server needs to be upgraded to .NET Framework version 4.8 or higher.
Download the Plant Integrations installation file
<trendminer-hc-X.Y.Z.zip>
from the TrendMiner download site.Before starting the upgrade, make a copy of your Plant Integration folder as a backup. This folder is usually located at C:\inetpub\PlantIntegrations.
When a connector backup needs to be restored, only copy the files within the main directory (e.g. "PlantIntegrations"). Never overwrite the directory itself. Overwriting the directory will clear all configured permissions on the directory which will prevent you from updating data sources or making changes to configuration from the TrendMiner application.
In the ConfigHub UI this can be recognized by the data source errors
500 Internal Server Error
orFailed Error on remote service - HttpCode: '500'
orAccess denied
To reset the permissions you can follow the instructions listed in the connector installation guide.
Stop the Plant Integrations application pool in ‘Application Pools’ to begin the upgrade steps.
Right-click on the website and choose ‘Deploy’ - ‘Import Application’.
Select the TrendMiner Plant Integrations zip archive and click ‘Next’.
Click ‘Next’.
Remove the Application Path to a blank field (default will show HC) and click ‘Next’.
Click ‘OK’ to continue. If this warning message does not appear, go back to the previous step.
Click ‘Next’.
Click ‘Finish’ to complete the Plant Integrations deployment.
Restore the old connector configuration by opening the new Web.config and the old Web.config from the backup folder with a text editor and comparing the settings. Any overridden settings should be manually updated in the new Web.config.
Start the Application Pool again.
