Prerequisites
  • My current installed TrendMiner version is 2022.R2.0 or higher.
    In case you are running on version 2022.R1.0 or older, please upgrade first to version 2022.R2.0.
  • I have VM console access.
  • I have updated the CentOS 7 default repository references.
    Avis
    This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance?How to check if TrendMiner is deployed as a virtual appliance?
    sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo
    sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
    Resource
    Minimum
    Recommended
    vCPU
    8
    16
    16
    RAM
    32GB
    64GB
    64GB
    Disk space
    SSD, 200GB, 250MB/s
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
  • All connectors are running on a Windows server with Microsoft .NET 4.8 or higher installed.
    As of connector version v4.13.0 the required .NET version is 4.8, compared to .NET 4.5.2 for previous releases.
