Notebook migration
These instructions only apply to customers who are using notebooks or used notebooks in the past and which to keep their notebooks after the upgrade.
As of the 2022.R2.0 release Zeppelin notebooks are replaced by Jupyter notebooks. The conversion from the notebooks needs to be done manually on your local computer.
Prerequisites
  • Python installation of version 3.6 or above
    Check with: python --version
  • nbformat version 5.0.2 or above
    pip install nbformat==5.0.2 or conda install nbformat==5.0.2
  • Download all the Zeppelin notebooks which you would want to migrate and save them locally. Note that all notebooks need to be exported one by one. There is no bulk export available.
  • Download the Python migration script to your local machine.
Migration
There are 2 options to migrate notebooks: via the CLI or by programming in Python.
Options
Description
input_file (mandatory)
Path to the input zeppelin notebook file.
ex: ./notebooks/example.zpln
output_filename (optional)
Name of the converted notebook file.
default : <zeppelin name>.ipynb
ex: example.ipynb
output_directry (optional)
Destinaton directory to save the converted notebook file.
default : <current directory>
ex: ./target
Migration via CLI
python path/to/migrate.py -i={input_file} -o={output_directry} -f={output_filename}
example:
python migrate.py -i=./notebooks/example.zpln -o=./target -f=example.ipynb
example shell script to migrate multiple zeppelin files in a folder:
for file in ./notebooks/*.zpln; do python migrate.py -i="$file" -o=./target; done
Migration via programming
import sys
sys.path.insert(0, /path/to/directory) # Replace with path to directory containing migrate.py
import migrate
input_file = /path/to/file # Replace with path to zeppelin notebook file
output_directry = None # or /path/to/output/directory
output_filename = None # or filename
migrate.main(input_file, output_directry, output_filename)
example to migrate multiple zeppelin files in a folder:
import sys
sys.path.insert(0, '.') # Replace with path to directory containing migrate.py
import migrate
import os
import re
input_directory = './notebooks' # Replace with path to directory containing zeppelin notebook files
output_directry = './target' # Replace with path to output directory
extension = '.zpln' # Change this to '.json' if you have your zeppelin files with .json extension
if os.path.exists(input_directory) and os.path.isdir(input_directory):
    for file in list(filter(lambda x: re.match(fr'.*\{extension}$',x.lower()), os.listdir(input_directory))):
        migrate.main(f"{input_directory}{os.sep}{file}", output_directry)
else:
    sys.stderr.write(f"error: Path '{input_directory}' does not exists or is not a valid directory!\n")
On successful migration, the script will print the path to the ipynb file.
As a precaution, do not delete the original notebooks after migration in case they are needed for further troubleshooting after the upgrade. It is only advised to delete them from your local machine after it has been confirmed they are working successfully in the new MLHub after the upgrade.
