Prerequisites
My current installed TrendMiner version is 2022.R1.0 or higher.
In case you are running on version 2021.R3.1 or older, please upgrade first to version 2022.R1.0.
I have VM console access.
I have a recent VM snapshot.
I have a recent database backup.
I have enough free disk space.
I have updated the CentOS 7 default repository references.
Avis
This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance?
sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
My system meets the minimum system requirements as listed below.
Resource
Minimum
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk space
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
The following prerequisites only apply to customers who are using notebooks or used notebooks in the past and wish to keep their notebooks after the upgrade:
I have a valid notebook and machine learning model licenses and the respective services are enabled.
To verify this please open the ConfigHub -> License menu.
I have successfully migrated my notebooks following the instructions in then next section.
