Batch Indexing Instructions
batch-indexing indexes the tags in a given list.
Step 1
Download the batch-indexing files:
https://files.trendminer.com/batch-indexing/2021R3.1/
When asked for username and password, use the corresponding customer files logins!
Scripts are executable from every windows-installation that has access to TrendMiner. There are different scripts included in the downloadable file. This article focuses on the batch-indexing.exe script.
Step 2
3 config files are provided:
Config.json
Config-batch.json
Config-performance.json
Config-performance is used to test the indexing performance (not included in these instructions).
In practice, you only need config-batch.json.
Open this file (preferably in notepad++) and adjust it according to the customer's setup. The following info is required to run batch indexing.
"TrendMinerSearch": "https://trendminer.example.org/hps/",
"ClientId": "tm-indexing",
"ClientSecret": "123e4567-e89b-12d3-a456-426614174099",
"BatchSize": 1
=TrendMinerSearch=
The TrendMiner Search address, usually ends in `/hps/`
=ClientId=
The client id to be used for all Indexing requests (In ConfigHub => Security => Clients)
=ClientSecret=
The secret for the corresponding client In ConfigHub => Security => Clients => Select Client => Options => Show secret)
=BatchSize=
The number of tags to index at once. Note that this does not override the number of connections in TrendMiner.Note
It is important to set the correct historian rights before triggering the batch indexing script. The indexing script uses a separate login flow to generate a security token. Logging in and out on the application itself does not have an effect on the token.
The client can be created on ConfigHub and it needs an acl (Access Management => Select Datasource => Add client). For more information about on how to create the clients, please refer to the Trendminer documentation.
The keyword ALL in the datasource access needs to be uppercase. In lowercase (all), it won’t work!
Step 3
Prepare a .txt file containing all tags which need to be indexed.
Format
No header
One tagname per row
Prefix of the historian needs to be added!
Example:
tags.txt
BA:CONC.1
[PI]BA:TEMP.1
Step 4
Move the .txt file and the config-batch.json file to the windows folder
Open a command window and navigate to the windows path containing the scripts, .txt and config-batch.json file:
Eg: cd C:\Users\John\Desktop\support-scripts\windows
For another drive it isn’ t cd, but to change the drive in Command Prompt (CMD) To access another drive, type the drive's letter, followed by ":".
For instance, if you want to change the drive from "C:" to "D:", you should type "d:"
Execute the following command:
batch-indexing.exe -tags short_tag_list.txt -min-free 0 -config config-batch.json
If everything works, you can increase the batch size in the config-batch file, e.g. to 3, and execute the command on the full tag list.
batch-indexing.exe -tags full_tag_list.txt -min-free 0 -config config-batch.json
