Known issues
  • Updates from 2021.R2.1 to 2021.R2.2 to 2021.R3.0 might result in a broken ConfigHub task queue. In case this happens, please contact TrendMiner support.
  • Cross asset value based search is currently not supported (and blocked) for string tags (i.e. digital tags for which no numerical value mapping exists on the historian). Digital tags for which a numerical value mapping exists on the historian are supported.
  • After restoring a backup the tm-zeppelin and the tm-zementis service need to be restarted manually.
  • Scooter values may change when zooming in after adding the scooter. This is due to the fact that scooters currently interpolate the data points on the chart.
  • The back button of the browser does not correctly restore the panel state.
  • Cloning a notebook will result in a copy of the notebook. The paragraphs of the copied notebook are still interlinked with the paragraphs of the original notebook. The "linked" paragraphs of both notebooks may be refreshed/updated based on the other notebook resulting in undesired behavior. It is advised to copy/paste your code manually for now.
  • Renaming a tag in the tag builder is not supported if the tag is linked to a Context item.
As from the 2022.R1 onwards, we will drop active support* for Internet Explorer 11 browsers, following Microsoft's recommendation to only use Internet Explorer for compatibility with older sites and applications. Ending support for IE 11 will allow us to use modern web practices to improve performance and user experience as we continue adding new features. Support for Microsoft Edge browser has been added instead.
* users will still be able to use IE11 with TrendMiner, but new features might no longer work + IE11 specific bugs/issues will no longer be solved. In a later stage, existing functionalities will also be adjusted to no longer have to cope with the restrictions of IE11.
