Bug fixes
  • We have improved the Recommendation Engine to make looking for candidate tags less resource-intensive, allowing running searches that contain a higher number of tags without hitting limitations on the system.
  • When the context item created by a monitor failed due to hiccups with our security service they were are also considered monitoring malfunctions, causing the monitor going to system-disabled. In these cases, the monitor won’t be system-disabled anymore.
  • When the trigger of a fingerprint monitor is deleted, the monitor will go to system-disabled, and will remain disabled after running the health check (instead of incorrectly re-enabling the monitor as a match fingerprint).
  • Monitors with malfunctioning context item creation actions will now also be system-disabled and a notification will be sent to inform the user.
  • Restricting Monitoring configuration API to admin role. Specifically how many active monitors we allow per user.
  • We fixed the issue with dashboards containing an old value tile with a timestamp.
  • Timestamps of chart exports and search results export are again formatted as custom Timestamps instead of text when opening in Excel.
